• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Contributor
    Deflection Settings
    181 Views, 1 Replies
    11-11-2012 08:47 PM
    In the attached file, when I display deflections under Results/Maps I get positive deflections under all applied loads. When I look at the deflected shape I can see the deflections are downwards (i.e. negative Z) so I would like to see a negative deflection. Is there a way to change the setting so the deflections become negative when I display them as described above?
    http://wtrns.fr/PlSFa4ne2e2xACk
    Thanks in advance,
    Jesper
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Deflection Settings
    11-12-2012 12:27 AM in reply to: Jesper.Jensen
    Jesper,
    Delete the mesh from panel 8 and mesh the panel again.
    Artur Kosakowski
    Support Specialist
    Product Support
