• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Mentor
    tony.ridley
    Accepted Solution
    Damping for seismic and spectral cases.
    357 Views, 5 Replies
    09-24-2012 06:12 PM
    Hi guys,
    • If I include damping in modal case that precedes the Spectral case, do I need to add a value for damping in the spectral definition?   If I include damping in the spectral definition and also check on damping in modal, does Robot "double up" on damping?
    • In the AS1170 seismic, there is no damping definition.  Do I need to check it on in Modal definition for it to be included?
    Tony
    Please use plain text.
    Product Support
    Re: Damping for seismic and spectral cases.
    09-25-2012 07:30 AM in reply to: tony.ridley
    Hi Tony,
    some summary on using damping in  modal, spectral and seismic cases.
    Damping defined in advanced parameters of modal case
    damping in modal.png is used in:
    1/ damping correction of elastic spectra in these seismic codes where it is possible - for instance in EN-1998-1-1 (Eurocode 8)
    2/ in calculation of complete quadratic combinations (CQC) and double sum method (2SM) combinations - see appropriate Help topic
    Damping defined in spectral analysis is not used directly in spectral analysis calculations- it can be treated as some identifier of various spectra here. It is used  when preparing spectra in case of spectra interpolation:interpolating spectra.png
    Above settings correspond to different actions so there is no risk to consider damping "twice".
    If this post answers your question please click "Accept as Solution". It will help everyone to find answer more quickly!
    Pawel Pulak
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Mentor
    tony.ridley
    09-25-2012 05:41 PM in reply to: pp2008
    Hi Pawel thanks for your reply.  What about this damping setting:
    Product Support
    09-26-2012 12:15 AM in reply to: tony.ridley
    This damping setting would be used only when using this spectra in Spectra Interpolation:
    Pawel Pulak
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Mentor
    tony.ridley
    09-26-2012 06:43 PM in reply to: pp2008
    Thanks for your reply Pawel,
    Perhaps the dialogue box should be removed from it's current position, it's a bit misleading.
    Thanks anyway,
    Tony
    Product Support
    10-01-2012 02:58 AM in reply to: tony.ridley
    Hi Tony,
    sorry for incomplete/incorrect answer in my previous post:
    damping from properties of spectra is used in spectra averaging not only in spectra definion but also when using averaged spectra directly in spectral load case - see the screen capture below:
    In such case the actual relative damping used to calculate averaged spectra will be taken from advanced parameters of modal case preceding this spectral case.
    Pawel Pulak
    Support Specialist
    Product Support
    Autodesk, Inc.
