• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Distinguished Contributor
    DESIGN - RC Columns Safety Factors
    90 Views, 2 Replies
    02-13-2013 07:57 AM
    Dear Colleagues
    Could I know why does the moment safety factor for the calculated column equals zero since any concrete section has capacity and there is applied loads ?
    Kindly ,  take a look to the attached model and capture .
    Note 01 : this case was occurred in elements  (4787,4788,4793 and 4794).
    Note 02 : if you use any capture for explanation . Please send it as attached
    http://www.2shared.com/file/O5PAcQiG/Columns_Safety_Factors.html
    Thanks in advance
    Refaat
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Columns Safety Factors
    02-14-2013 12:49 AM in reply to: refaat
    The 'basic' value of capacity calculated by Robot is Rd/Sd value and this one should be used as the primary reference..
    The other two are sort of informative: what would be the bending capacity for given level of axial force and vice versa. In case of the compression forces being above the critical one there is no 'additional' bending capacity in the column.
    Artur Kosakowski
    Support Specialist
    Product Support
    02-14-2013 01:17 AM in reply to: Artur.Kosakowski
    Dear Artur
    Clear , thanks for your perfect response
    Refaat
