Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
DESIGN - RC BEAMS - Armed Beams
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In the module for the manual assembly of beams has detected the following problem: After entering the armors and calculated the beam, the program does not consider the lower reinforcement in the beam resulting in that section and that does not meet resistance bending moments positvos to zero .. When going to see the diagrams of results in the corresponding flange concrete reinforced module shows that diagrmas not appear in the bottom of the graph corresponding to the resistance due to the lower positive reinforcement
Re: Armed Beams
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Could you send the rtd file with such beam? How the reinforcement was created - generated by Robot or using the typical reinforcement dialog? Other way?
Artur Kosakowski
Support Specialist
Product Support
Re: Armed Beams
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you.
The reinforcement has been created using the typical reinforcement dialog.
Please find attached the .rtd file with the beam. The file has been zipped in order to send it to the discussion group.
Regards.
Re: Armed Beams
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Follow the steps shown on the attached picture.
Artur Kosakowski
Support Specialist
Product Support
Re: Armed Beams
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Tahnk you.
We tried your solution but the problem persists.
Attached is a picture with the armed beam diagram.
Regards.
Re: Armed Beams
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
http://screencast.com/t/6B08ILGgR
Artur Kosakowski
Support Specialist
Product Support
Re: Armed Beams
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We are unable to do the same as on your video. We have tested three worksation with Robot.
We are using Robot 2013 and Windos 7 64 bit on a Dell Optiplex 380.
Thank you.
Re: Armed Beams
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Send me the rtd file and a picture that shows the actual issue please.
Artur Kosakowski
Support Specialist
Product Support
Re: DESIGN - RC BEAMS - Armed Beams
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The .rtd and image you requested.
regards.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
As far as I can see the diagram is displayed correctly when you first freeze reinforcement and then launch calculations as shown on the attached picture.
Try to install SP3 for Robot 2013 from:
Artur Kosakowski
Support Specialist
Product Support
