• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Member
    ALEJANDROFELGUEROSAFUENTES1370
    DESIGN - RC BEAMS - Armed Beams
    298 Views, 10 Replies
    01-23-2013 03:28 AM
    In the module for the manual assembly of beams has detected the following problem: After entering the armors and calculated the beam, the program does not consider the lower reinforcement in the beam resulting in that section and that does not meet resistance bending moments positvos to zero .. When going to see the diagrams of results in the corresponding flange concrete reinforced module shows that diagrmas not appear in the bottom of the graph corresponding to the resistance due to the lower positive reinforcement
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Armed Beams
    01-23-2013 03:50 AM in reply to: ALEJANDROFELGUEROSAFUENTES1370
    Could you send the rtd file with such beam? How the reinforcement was created - generated by Robot or using the typical reinforcement dialog? Other way?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    Re: Armed Beams
    01-23-2013 04:36 AM in reply to: Artur.Kosakowski
    Thank you.
    The reinforcement has been created using the typical reinforcement dialog.
    Please find attached the .rtd file with the beam. The file has been zipped in order to send it to the discussion group.
    Regards.
    Product Support
    Artur.Kosakowski
    Re: Armed Beams
    01-23-2013 05:09 AM in reply to: ALEJANDROFELGUEROSAFUENTES1370
    Follow the steps shown on the attached picture.
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    Re: Armed Beams
    01-24-2013 09:27 AM in reply to: Artur.Kosakowski
    Tahnk you.
    We tried your solution but the problem persists.
    Attached is a picture with the armed beam diagram.
    Regards.
    Product Support
    Artur.Kosakowski
    Re: Armed Beams
    01-25-2013 01:20 AM in reply to: ALEJANDROFELGUEROSAFUENTES1370
    http://screencast.com/t/6B08ILGgR
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    Re: Armed Beams
    02-13-2013 06:19 AM in reply to: Artur.Kosakowski
    We are unable to do the same as on your video. We have tested three worksation with Robot.
    We are using  Robot 2013 and Windos 7 64 bit on a Dell Optiplex 380.
    Thank you.
    Product Support
    Artur.Kosakowski
    Re: Armed Beams
    02-13-2013 06:28 AM in reply to: ALEJANDROFELGUEROSAFUENTES1370
    Send me the rtd file and a picture that shows the actual issue please.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    Re: DESIGN - RC BEAMS - Armed Beams
    02-13-2013 09:08 AM in reply to: ALEJANDROFELGUEROSAFUENTES1370
    The .rtd and image you requested.
    regards.
    Product Support
    Artur.Kosakowski
    02-14-2013 02:02 AM in reply to: ALEJANDROFELGUEROSAFUENTES1370
    As far as I can see the diagram is displayed correctly when you first freeze reinforcement and then launch calculations as shown on the attached picture.
    Try to install SP3 for Robot 2013 from:
    Robot2013SP3
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
