• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Mentor
    tony.ridley
    Re: Curtain walls and modal analysis
    06-25-2012 01:34 AM in reply to: RG_Adsk
    Here it is
    Please use plain text.
    Product Support
    Artur.Kosakowski
    06-25-2012 02:26 AM in reply to: tony.ridley
    Tony,
    Am I right saying that you have only claddings (no materials properties assigned) in your model? I think that you should replace them with curtain walls that have their self-weight included in the modal analysis.
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Mentor
    tony.ridley
    06-25-2012 04:04 AM in reply to: Artur.Kosakowski
    NO, I was running the model with claddings but also with user defined calculation options for mesh (check the "BONDEK" definition.
    I changed BONDEK to "Deck Slab" and it works OK.
    Product Support
    Artur.Kosakowski
    06-25-2012 04:36 AM in reply to: tony.ridley
    Tony,
    Please look at post 5 and the pictures attached there. I'm very sorry if I'm wrong but it seems that you missed the fact that to include self-weight of claddings you have to use load to mass conversion (and switch off use of self-weight in the modal analysis parameters). I made a quick test with the 'right' settings and Bondek panel calculation model assigned to panels 83 and 1931 obtaining similar results for introduced self-weight case case and modal analysis total mass.
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Mentor
    tony.ridley
    06-25-2012 04:45 AM in reply to: Artur.Kosakowski
    Yes thats what I was missing.  Thanks!
    Tony
