Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Curtain walls and modal analysis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Dear friends
Please check my conclusion about using Curtain walls in modal analysis. In first model I used Curtain wall and obtained the following results:
In second model I used equal loads and obtain different results:
Also, I made load to mass conversion with coefficient 1. Certainly, I checked model without any curtain walls and loads except self weight. The results coincided with the first model. My opinion is that we cannot use curtain walls in modal analysis, because they don’t taken into account. Maybe I'M wrong ![]()
Re: Curtain walls and modal analysis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Two points:
1. Robot in order to be able to distribute load (including self weight) from curtain wall needs to detect supporting objects which can be either a panel edge or a beam. In your case the floor panels should be defined as starting/ending at the partition wall locations rather than as a single panels for the entire floor or you should add fake beams under the partition walls.
2. You may consider if the self weight of a partition wall should be modeled as a linear load at the location where the partition wall is 'now' as an owner of the building may change thits location (or add new) at some point in time ('later'). Perhaps you can think about adding some uniform load on the floor panel instead?
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Let me give detailed answer.
First model - curtain walls with fake beams:
Second model - equal loads without any partition walls and fake beams:
As you can see, results from static analysis approximately the same. But results from Modal analysis is different. Maybe Robot have hidden ability to convert automatically generated forces in masses? I think the problem in this.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It is hard for me to discuss a particular situation without looking at the corresponding model but in general (some restrictions may apply) :
1. Cladding load (load generated by triangular and trapezoidal distribution method) is taken into account for static analysis provided the load carrying object can be detected (see bending moment diagram for case 2 on the attached picture 2)
2. Such load can be converted into mass (and this is standard rather than hidden functionality of Robot) in the way shown on picture 1.
3. Such generated mass is taken into account for modal analysis (in my example this is the only mass as the disregard density option is switched on in the parameters of the modal analysis).
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am running 2013 with SP1 and I'm getting the problem of curtain wall not being including in modal mass. I will send file via large file transfer to Artur/Rafal if you are interested.
Tony
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Save as under new name as rtd without results, then zip, then send.
Rafal Gaweda
Product Support
