• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Member
    Henkac
    Accepted Solution
    Critical moment
    262 Views, 4 Replies
    02-16-2012 07:50 AM
    I have studied the critical moment that Robot uses a little deeper and I need an explanation to the attached simple example:
    A beam with 4 supports gets a much lower Mcr when it's connected over the middle supports than it has when its released over the supports.
    I checked it with another program that calculates Mcr (LTBeam) and with LTBeam the Mcr is about 10% higher when the beams are connected
    Product Support
    Artur.Kosakowski
    Re: Critical moment
    02-17-2012 04:51 AM in reply to: Henkac
    I have made a quick hand calcs for  a similar beams and I can't see any problem with values in Robot.
    Please in case you have some doubts about the numbers try to do the same yourself first. I'm not able to do this for every post on the forum.:smileyhappy:
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Участник
    Re: Critical moment
    02-17-2012 06:32 AM in reply to: Henkac
    Maybe this could help. It says that 2 methods give similar results.
    Active Member
    Henkac
    Re: Critical moment
    02-20-2012 01:10 AM in reply to: Henkac
    Thanks for the help.
    The problem for me was that I didn't have access to ENV 1993-1-1 only to EN 1993-1-1 where the method of calculating Mcr that Robot uses no longer is described. But thanks to Участник I was able to find the document SN003 where it is described also.
    So now I could calculate it and understand the way Robot calculates Mcr. The result from my calculation with this method was the same as Robots value of Mcr.
    Maybe it could be nice to have the possibility to give the value of Mcr to Robot if you have used some other program or method to calculate it?
    Regards Henrik C
    Product Support
    Artur.Kosakowski
    Re: Critical moment
    02-20-2012 02:15 AM in reply to: Henkac
    This proposal has been added to the wish list.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
