• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Moderator
    Romanich
    Accepted Solution
    Creation panel with FE list
    352 Views, 8 Replies
    06-28-2012 10:29 PM
    Hello friends,
    When I change the thickness of panel by using option Creation with FE list, only  self weight has been applied to FE with new thickness. Other loads automatically not transfered. It's a bug or feature?
    Please use plain text.
    Valued Mentor
    tony.ridley
    Re: Creation panel with FE list
    06-28-2012 10:39 PM in reply to: Romanich
    Not sure but seems logical to me that loads would not be replicated as loads are normally "hosted" to the contour edge (my guess ?) which would have been re-defined by creating the new panel from elements.
    Tony
    Moderator
    Romanich
    06-28-2012 10:46 PM in reply to: tony.ridley
    Hi Tony,
    Also existing loads (which has been applied to first FE) is inactive.
    Valued Mentor
    tony.ridley
    06-28-2012 11:06 PM in reply to: Romanich
    Ahhh so you create panel from FE's, add loads, then change thickness and loads dissappear?  Sounds like bug!
    Like the one I get when I change thickness it defaults back to "Curtain Wall" and I have to make shell again
    Product Support
    06-29-2012 12:44 AM in reply to: tony.ridley
    It is "as designed" - when creating new panel from the list of finite elements the loads assigned to panels (where the lists of loaded panels are not automatically updated - see Note) are not inherited by the new one.
    One of the reasons is that the list of finite elements can contain elements  from several adjacent panels. In such case it is not clear what to do when appropriate load is not applied to all of them.
    Of course in practice (in more than 90% of cases I suppose) finite elements are taken from one panel. The improvement suggestion to inherit panel loads in such case was registered :smileyhappy:
    Note:  the loads assigned to panels, where the lists of loaded panels are automatically updated, are self-weight load for "Whole structure" and the load on contour when "Automatic panel selection in the contour plane" is active
    If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
    Pawel Pulak
    Support Specialist
    Product Support
    Autodesk, Inc.
    Moderator
    Romanich
    06-29-2012 12:59 AM in reply to: pp2008
    Pawel, thank you. Maybe this must be inclusive in help?
    Product Support
    06-29-2012 01:44 AM in reply to: Romanich
    Roman,
    the request to complete Help with his information was registered:smileyhappy:
    Pawel Pulak
    Support Specialist
    Product Support
    Autodesk, Inc.
    Distinguished Contributor
    09-14-2012 07:30 AM in reply to: pp2008
    you can video tutorial Creation panel with FE list????
    Product Support
    09-17-2012 01:53 AM in reply to: A.wikipedia
    Here is the link to video I registered:
    http://screencast.com/t/GxgtEue5bFf
    Please notice that after the creation of panel from the list of finite elements the  FE meshes of the original and new panels are automatically frozen.
    Pawel Pulak
    Support Specialist
    Product Support
    Autodesk, Inc.
