• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Continuous footings combinations.
    171 Views, 2 Replies
    10-27-2011 07:39 AM
    Hi all,
    is it posible to include manual combinations into  continuous footing analysis?
    No matter what i've tried, robot only includes simple cases or combinations that have been generated automaticaly.
    Thank you.
    Please use plain text.
    Product Support
    Re: Continuous footings combinations.
    10-27-2011 08:00 AM in reply to: MARIOS75
    Hi
    If you import such footing from model it should be possible to select either simple cases or combinations
    Rafal Gaweda
    Product Support
    10-27-2011 08:49 AM in reply to: MARIOS75
    Thanks Rafal,
    i'm attaching some screenshots.
    I think there is a bug.
    9 out of 10 times robot won't accept the manual combination.
    In case that accepts it this will cause problems to  the flange bending moments diagram.
