Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Concrete strenght
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi all
I have this Question
In the RC Module Choosing the material for concete as H250 in the calculations options
After calculating the reinforcement, in the drawings appears as H225
Setting again in the Job Preferences for concrete H250
Once in the final drawing appears as H250
Then for the next beam appears as HORMIGON
How to fix with the right value?
Please see the attached file with the beam drawings
Re: Concrete strenght
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Could you send the rtd file please? You can delete all but one H-225 and Hormigon beams to make it smaller.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The attached the file contains only 2 beams at level 3.15 m
There also nodes that are not selectable with the mouse
The file is opened in repair mode because the file size for two beams 61.8 Mb
After delete of all the final drawings, closed all the windows in the Geometry / Results layout
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The way you saved the file caused the beams to be no longer available in the RC Beam design module. Looking at the model you sent I can see that these are the materials you assigned to the beams which makes me think that the actual definition of the material in the RC Beam design module could be 'as in the model'.
I can't see issue with node selection either.
Artur Kosakowski
Support Specialist
Product Support
