• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Contributor
    Concrete strenght
    155 Views, 3 Replies
    08-12-2012 10:25 PM
    Hi all
    I have this Question
    In the RC Module Choosing the material for concete as H250 in the calculations options
    After calculating the reinforcement, in the drawings appears as H225
    Setting again in the Job Preferences for concrete H250
    Once in the final drawing appears as H250
    Then for the next beam appears as HORMIGON
    How to fix with the right value?
    Please see the attached file with the beam drawings
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Concrete strenght
    08-13-2012 12:24 AM in reply to: rioja
    Could you send the rtd file please? You can delete all but one H-225 and Hormigon beams to make it smaller.
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Contributor
    08-13-2012 09:38 AM in reply to: Artur.Kosakowski
    The attached the file contains only 2 beams at level 3.15 m
    There also nodes that are not selectable with the mouse
    The file is opened in repair mode because the file size for two beams 61.8 Mb
    After delete of all the final drawings, closed all the windows in the Geometry / Results layout
    Product Support
    Artur.Kosakowski
    08-14-2012 02:14 AM in reply to: rioja
    The way you saved the file caused the beams to be no longer available in the RC Beam design module. Looking at the model you sent I can see that these are the materials you assigned to the beams which makes me think that the actual definition of the material in the RC Beam design module could be 'as in the model'.
    I can't see issue with node selection either.
    Artur Kosakowski
    Support Specialist
    Product Support
