• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Distinguished Contributor
    gustavo.c.vasconcellos
    Composite beam Design in Robot
    1055 Views, 6 Replies
    08-12-2011 12:10 PM
    I would like to know how can I design a composite beam in Robot.
    I tried using Revit Structure:  updating the model and using Composite Design Extension, but, as I designed load (including moving load), and load combination in Robot I am not feeling confortable. I can't see all the loads in Revit.
    When I updated the model, I chose the option to transfer results (reactions and internal forces).
    Am I missing something? Is there a better way desinging directly in Robot? Or am I doing right?
    Gustavo Vasconcellos
    Please use plain text.
    Product Support
    jad.dellel
    Re: Composite beam Design in Robot
    08-15-2011 04:52 AM in reply to: gustavo.c.vasconcellos
    The Revit Extension Composite Steel Beam Design is only available for the AISC Standard Wide Flange shapes, I invite you to read the white paper: http://images.autodesk.com/adsk/files/autodeskrobot_revitstructure_whitepaper_final.pdf
    You can also use the Robot Expert tool (according to Eurocode 4):
    Or use the Composite Structures' sheet within Robot Extensions- Spreadsheet Calculator:
    Jad DELLEL
    Structural Engineering Product Support Autodesk, Inc.
    08-15-2011 07:19 AM in reply to: jad.dellel
    Dear Jad,
    First of all, I would like to thank you for your reply, but I have some more questions:
    - If I am using AISC Standard Wide Flange shapes and model the loads on Robot, do the loads transfer to Revit when I update from Revit?
    - I tried the spreadsheet calculator but it appears as a demo version, what should I do?
    - Is there any white paper about the spreadsheet calculator, like the one that you send to me about Composite Design?
    Product Support
    jad.dellel
    08-15-2011 07:31 AM in reply to: gustavo.c.vasconcellos
    Hi Gustavo,
    There's answers for your questions:
    Yes, after importing your structure in Revit Structures, It should work but your structure must fulfill the requirements of this extension, please check its in "About the extension" .
     Please read our post here: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Robot-Extensions-Spreadsheet-Calculator2012/...
    No white paper available for SPC, but you can find generally detailed help with some calculations examples for each sheet.
    Jad DELLEL
    Valued Contributor
    mpcloob
    02-07-2013 12:24 AM in reply to: jad.dellel
    how can i download Robot expert tool for composite beam design ?
    Product Support
    jad.dellel
    02-07-2013 05:56 AM in reply to: mpcloob
    Hello Mohammed,
    You should have a subscription contract first then, you could download it from subscription.autodesk.com
    Jad DELLEL
    Valued Contributor
    mpcloob
    02-09-2013 03:07 AM in reply to: jad.dellel
    in the name of  GOD .
    I'm a student.I haven't this.
    Those who are students do not give Extensions & Plug-ins ? :smileysad::smileysad:
    unless the person who is a student? :smileysad::smileysad::smileysad::smileysad:
    we had expected more from Autodesk company :smileysad::smileysad:
    Autodesk does not respect us unfortunately, but yet we love it :smileysad::smileysad:
    we don't want extensions for Revit only, we want free extensions for other program that available in Autodesk student website too.
    please tell this matter to Autodesk company
