Compatible nodes?
Compatible nodes?
Compatible nodes?
Hi!
I can not resolve the situation in Figure 1.
I want to fix the bar 7 to 5, but not to the bars 4 and 6 (see figure 2).
I think it is compatible with nodes, but I can not.
Greetings and thank you very much for the help
Rafal.Gaweda
Autodesk Support
Autodesk Support
You need to split bars and create compatibility this way : http://screencast.com/t/jiCevbcxX
The easiest approach in this case:
Rafal Gaweda
