• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Product Support
    Re: Command VBA Projection Capture of a view
    12-12-2011 06:55 AM in reply to: mateaus
    Try this:
    mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_NODE_NUMBERS, True
    mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_BAR_NUMBERS, True
    RobApp.Project.ViewMngr.Refresh
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Please use plain text.
    Distinguished Contributor
    mateaus
    12-12-2011 08:32 AM in reply to: RG_Adsk
    It doesn't work
    error
    I would like also change the size of symbols like :
    mavueRobot.ParamsDisplay.SymbolSize = 5
    This command doesn't change anything.
    Product Support
    12-12-2011 08:37 AM in reply to: mateaus
    I asked you to use this syntax:
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    mateaus
    12-12-2011 09:45 AM in reply to: RG_Adsk
    Ok sorry and for the syze of symbols ?
    Active Contributor
    sorgjee
    12-12-2011 01:25 PM in reply to: mateaus
    Re SymbolSize; is it correct that this only takes an integer, and that the symbolsize represented in Robot is ten times of this?
    E.g. SymbolSize = 2 gives a symbol size in robot of 20.
    Similarly SymbolSize = 1.5 gives 20, and SymbolSize = 1.4 give 10.
    Product Support
    12-13-2011 12:48 AM in reply to: sorgjee
    and that the symbolsize represented in Robot is ten times of this?E.g. SymbolSize = 2 gives a symbol size in robot of 20.
    Yes it is like that. 1 in API coresponds to 10 in Robot.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    mateaus
    12-13-2011 10:16 AM in reply to: sorgjee
    It doesn't work, can you send me an example ?
    'mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_NODE_NUMBERS = True
    'mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_BAR_NUMBERS = True
    mavueRobot.ParamsDiagram.Set I_VDRT_NTM_FX, False
    mavueRobot.ParamsDiagram.Set I_VDRT_NTM_FZ, False
    mavueRobot.ParamsDiagram.Set I_VDRT_NTM_MY, False
    'mavueRobot.ParamsDisplay.Set I_VDA_ADVANCED_OFFSETS, True
    mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_SHAPE, True
    mavueRobot.ParamsDisplay.Set I_VDA_ADVANCED_ELASTIC_FOUNDATION, True 'afficher sol elastique
    'mavueRobot.ParamsDisplay.Set I_VDA_FE_PANEL_THICKNESSES, True
    'mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_COLORS, True
    mavueRobot.Redraw (0)
    mavueRobot.ParamsDisplay.SymbolSize = 2
    robapp.Project.ViewMngr.Refresh
    Product Support
    12-14-2011 12:59 AM in reply to: mateaus
    mateaus
    01-09-2012 10:59 AM in reply to: RG_Adsk
    I'd like to ask in the view this :
    Reaction Fx
    How can I make it ?
    Product Support
    01-10-2012 02:20 AM in reply to: mateaus
    Reaction Fx
    Unfortunately it is not implemented in API.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
