• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    mateaus
    Re: Command VBA Projection Capture of a view
    11-15-2011 04:40 AM in reply to: mateaus
    I would like to modify the layout. I prefer without the object manager and with the rules.
    Can you give me the command ? I think it's with IRobotLayoutId and IRobotViewMngr.
    Please use plain text.
    mateaus
    11-15-2011 04:43 AM in reply to: RG_Adsk
    I already read it. I need more explanations if it's possible.
    Product Support
    11-15-2011 05:34 AM in reply to: mateaus
    Ruler :
    mavueRobot.ParamsDisplay.Set I_VDA_OTHER_RULER, True
    robapp.Project.ViewMngr.Refresh
    Object Inspector - not possible to open \ close it by API
    Rafal Gaweda
    Product Support
    mateaus
    11-18-2011 08:55 AM in reply to: RG_Adsk
    Ok I would like to activate also with VBA :
    excentrements
    Croquis barres
    epaisseur panneaux
    profilés couleurs
    Can you give me the VBA command ?
    Product Support
    11-20-2011 11:54 PM in reply to: mateaus
    mavueRobot.ParamsDisplay.Set I_VDA_ADVANCED_OFFSETS, True
    mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_SHAPE, True
    mavueRobot.ParamsDisplay.Set I_VDA_FE_PANEL_THICKNESSES, True
    mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_COLORS, True
    Rafal Gaweda
    Product Support
    mateaus
    11-21-2011 02:41 AM in reply to: RG_Adsk
    I would like to give the name to a screen capture wich is the name of the load :
    Dim ScPar As RobotViewScreenCaptureParams
    Set ScPar = robapp.CmpntFactory.Create(I_CT_VIEW_SCREEN_CAPTURE_PARAMS)
    ScPar.Name = ???
    I think it's something with get and from text ?
    For example "3 : Equipements"
    mateaus
    11-21-2011 03:21 AM in reply to: RG_Adsk
    I have got a problem with the display. The symbol of loads doesn't appear.
    The refresh is not done. Have you got an idea ?
    mavueRobot.ParamsDisplay.Set I_VDA_ADVANCED_OFFSETS, False      'afficher exentrements
    mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_SHAPE, False        'afficher croquis barres
    mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_SYMBOLS, True       'afficher symboles barres
    mavueRobot.ParamsDisplay.Set I_VDA_FE_PANEL_THICKNESSES, False  'afficher epaisseur panneaux
    mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_COLORS, False       'afficher profilés en couleur
    mavueRobot.ParamsDisplay.Set I_VDA_FE_FE_INTERIOR, False        'interieur element finis
    mavueRobot.ParamsDisplay.Set I_VDA_FE_CLADDING_INTERIOR, False  'interieur bardages
    mavueRobot.ParamsDisplay.Set I_VDA_FE_PANEL_INTERIOR, False     'interieur panneaux
    mavueRobot.ParamsDisplay.Set I_VDA_FE_FINITE_ELEMENTS, False    'afficher elements finis
    mavueRobot.ParamsDisplay.Set I_VDA_LOADS_VALUES, True               'valeurs charges
    mavueRobot.ParamsDisplay.Set I_VDA_LOADS_SYMBOLS_UNIFORM_SIZE, True '
    mavueRobot.ParamsDisplay.Set 68, True                               'symbole charges ponctuelles
    mavueRobot.ParamsDisplay.Set 69, True                               'symbole charges lineaires
    mavueRobot.ParamsDisplay.Set 70, True                               'symbole charges surfaciques
    For i = 1 To 3
    mavueRobot.Selection.Get(I_OT_CASE).FromText (i) ' selecting case
    mavueRobot.Redraw (0)
    ecran_capture = "charges" & i
    Call screen_capture
    Next i
     image result
    Product Support
    11-21-2011 05:24 AM in reply to: mateaus
    I have got model from you once. There are no loads in case 1 and 3 so there is nothing to be displayed
    Case 2 works fine.
    mavueRobot.Visible = True
    'mavueRobot.Redraw (True)
    mavueRobot.ParamsDisplay.Set I_VDA_OTHER_RULER, False
    mavueRobot.ParamsDisplay.Set I_VDA_LOADS_SYMBOLS_CONCENTRATED, True
    mavueRobot.ParamsDisplay.Set I_VDA_LOADS_SYMBOLS_LINEAR, True
    mavueRobot.ParamsDisplay.Set I_VDA_LOADS_SYMBOLS_PLANAR, True
    RobApp.Project.ViewMngr.Refresh
    ' making screen capture
    Set ScPar = RobApp.CmpntFactory.Create(I_CT_VIEW_SCREEN_CAPTURE_PARAMS)
    For i = 1 To 3
    ScPar.Name = "My screen capture" + Str(i)
    ScPar.UpdateType = I_SCUT_UPDATED_UPON_PRINTING
    mavueRobot.MakeScreenCapture ScPar
    Next i
    Rafal Gaweda
    Product Support
    mateaus
    11-21-2011 06:01 AM in reply to: RG_Adsk
    It doesn't work, look at the video :
    demo
    I have to select by myself the case of load in the model.
    Refresh doesn't work.
    Product Support
    11-21-2011 07:16 AM in reply to: mateaus
    Movie of my code
    I am using ARSA 2012, but the same effect I got on 2011
    Rafal Gaweda
    Product Support
