Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Command VBA Projection Capture of a view
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I would like to modify the layout. I prefer without the object manager and with the rules.
Can you give me the command ? I think it's with IRobotLayoutId and IRobotViewMngr.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I already read it. I need more explanations if it's possible.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ruler :
mavueRobot.ParamsDisplay.Set I_VDA_OTHER_RULER, True
robapp.Project.ViewMngr.Refresh
Object Inspector - not possible to open \ close it by API
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ok I would like to activate also with VBA :
Can you give me the VBA command ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
mavueRobot.ParamsDisplay.Set I_VDA_ADVANCED_OFFSETS, True
mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_SHAPE, True
mavueRobot.ParamsDisplay.Set I_VDA_FE_PANEL_THICKNESSES, True
mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_COLORS, True
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I would like to give the name to a screen capture wich is the name of the load :
Dim ScPar As RobotViewScreenCaptureParams
Set ScPar = robapp.CmpntFactory.Create(I_CT_VIEW_SCREEN_CAPTUR
ScPar.Name = ???
I think it's something with get and from text ?
For example "3 : Equipements"
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have got a problem with the display. The symbol of loads doesn't appear.
The refresh is not done. Have you got an idea ?
mavueRobot.ParamsDisplay.Set I_VDA_ADVANCED_OFFSETS, False 'afficher exentrements mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_SHAPE, False 'afficher croquis barres mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_SYMBOLS, True 'afficher symboles barres mavueRobot.ParamsDisplay.Set I_VDA_FE_PANEL_THICKNESSES, False 'afficher epaisseur panneaux mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_COLORS, False 'afficher profilés en couleur mavueRobot.ParamsDisplay.Set I_VDA_FE_FE_INTERIOR, False 'interieur element finis mavueRobot.ParamsDisplay.Set I_VDA_FE_CLADDING_INTERIOR, False 'interieur bardages mavueRobot.ParamsDisplay.Set I_VDA_FE_PANEL_INTERIOR, False 'interieur panneaux mavueRobot.ParamsDisplay.Set I_VDA_FE_FINITE_ELEMENTS, False 'afficher elements finis mavueRobot.ParamsDisplay.Set I_VDA_LOADS_VALUES, True 'valeurs charges mavueRobot.ParamsDisplay.Set I_VDA_LOADS_SYMBOLS_UNIFORM_SIZE, True ' mavueRobot.ParamsDisplay.Set 68, True 'symbole charges ponctuelles mavueRobot.ParamsDisplay.Set 69, True 'symbole charges lineaires mavueRobot.ParamsDisplay.Set 70, True 'symbole charges surfaciques For i = 1 To 3 mavueRobot.Selection.Get(I_OT_CASE).FromText (i) ' selecting case mavueRobot.Redraw (0) robapp.Project.ViewMngr.Refresh ecran_capture = "charges" & i Call screen_capture Next i
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have got model from you once. There are no loads in case 1 and 3 so there is nothing to be displayed
Case 2 works fine.
mavueRobot.Visible = True
'mavueRobot.Redraw (True)
mavueRobot.ParamsDisplay.Set I_VDA_OTHER_RULER, False
mavueRobot.ParamsDisplay.Set I_VDA_LOADS_SYMBOLS_CONCENTRATED, True
mavueRobot.ParamsDisplay.Set I_VDA_LOADS_SYMBOLS_LINEAR, True
mavueRobot.ParamsDisplay.Set I_VDA_LOADS_SYMBOLS_PLANAR, True
RobApp.Project.ViewMngr.Refresh
' making screen capture
Set ScPar = RobApp.CmpntFactory.Create(I_CT_VIEW_SCREEN_CAPTUR
For i = 1 To 3
ScPar.Name = "My screen capture" + Str(i)
ScPar.UpdateType = I_SCUT_UPDATED_UPON_PRINTING
mavueRobot.MakeScreenCapture ScPar
Next i
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It doesn't work, look at the video :
I have to select by myself the case of load in the model.
Refresh doesn't work.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am using ARSA 2012, but the same effect I got on 2011
Rafal Gaweda
Product Support
