• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    mateaus
    Re: Command VBA Projection Capture of a view
    10-14-2011 03:11 AM in reply to: RG_Adsk
    OK thanks a lot
    Please use plain text.
    mateaus
    11-10-2011 01:07 AM in reply to: RG_Adsk
    Hi I would like to make a zoom of my picture because I can't anything on my screen capture. I wrote this command but it's not good written. Would you mind correct it ?
    mavueRobot.GetZoom(2, 2, 2, 2) = 1
    I would like make a zoom of 150%.
    Product Support
    11-10-2011 06:32 AM in reply to: mateaus
    It is not that easy because zoom depends on real coordinates and viewport size \ aspect ratio.
    Small 2d example below. Left top corner is important and vieport aspect ratio
    3d example  (left top corner is related to left top corner on ZX plain view) ; additionally you should define rotation point and rotation angle
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    mateaus
    11-14-2011 04:01 AM in reply to: RG_Adsk
    Hi it did'nt work.
    I send you a video which show what I want to do ?
    Would you mind send me the command of VBA to write in the macro for it ?
    Product Support
    11-14-2011 05:49 AM in reply to: mateaus
    Try this - change zoomfactor:
    Set RobApp = New RobotApplication
    Dim viewRobot As IRobotView3
    Set viewRobot = RobApp.Project.ViewMngr.GetView(1)
     viewRobot.Redraw (True)
    viewRobot.Projection = I_VP_XY
    viewRobot.ParamsFeMap.CurrentResult = I_VFMRT_DETAILED_MOMENT_XY
    RobApp.Project.ViewMngr.Refresh
    Dim l As Double, t As Double, b As Double, r As Double
    l = 0
    t = 0
    b = 0
    r = 0
    viewRobot.GetZoom l, t, r, b
    Dim CenterX As Double
    Dim CenterY As Double
    Dim VX As Double
    Dim VY As Double
    CenterX = (l + r) / 2
    CenterY = (t + b) / 2
    Dim zoomfacfor As Double
    zoomfactor = 2
    VX = Abs(l - CenterX) / zoomfactor
    VY = Abs(t - CenterY) / zoomfactor
    viewRobot.SetZoom CenterX + VX, CenterY + VY, CenterX - VX, CenterY - VY
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    mateaus
    11-14-2011 08:47 AM in reply to: RG_Adsk
    It doesn't change anything in the view. Have a look to the video.
    Product Support
    11-14-2011 10:53 AM in reply to: mateaus
    viewRobot.Redraw(True) ' <- I have not used this command, take a look in my code or use   ...Redraw(0)
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    11-14-2011 11:23 AM in reply to: RG_Adsk
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Zoom-All-via-API/td-p/3221266 ->
    .Redraw(1) ~ ZoomAll
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    mateaus
    11-15-2011 04:24 AM in reply to: RG_Adsk
    I don't understand what does mean left, top, right and bottom for the command getzoom ?
    Product Support
    11-15-2011 04:29 AM in reply to: mateaus
    Take  a look at my screen shots in message 23 in this thread
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
