• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    mateaus
    Command VBA Projection Capture of a view
    823 Views, 104 Replies
    10-12-2011 02:50 AM
    I have a problem with my macro. The command of projection in 3D doesn't work. My view stay in XZ plane.
    robapp.Window.Activate
    Set mavueRobot = robapp.Project.ViewMngr.CreateView(1)
    mavueRobot.Projection = I_VP_3DXYZ
    mavueRobot.Visible = True
    mavueRobot.Redraw (True)
    I want also make a capture of my model with diagram of results. Have you an example of code for it ?
    I would like to get for final result the exemple in attachment.
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Command VBA Projection Capture of a view
    10-12-2011 03:31 AM in reply to: mateaus
    Seems like one line is missing:
    robapp.Project.ViewMngr.Refresh
    Artur Kosakowski
    Support Specialist
    Product Support
    mateaus
    10-12-2011 10:22 AM in reply to: mateaus
    Ok but it's not working.
    See my attachment
    Product Support
    Artur.Kosakowski
    10-13-2011 12:01 AM in reply to: mateaus
    It seems like you missed the attachment.
    Artur Kosakowski
    Support Specialist
    Product Support
    mateaus
    10-13-2011 01:01 AM in reply to: Artur.Kosakowski
    Product Support
    10-13-2011 01:08 AM in reply to: mateaus
    Hi
    Take a look at attached movie
    Rafal Gaweda
    Product Support
    Product Support
    10-13-2011 01:20 AM in reply to: mateaus
    Hi
    It seems it is related to your computer graphics card (and maybe also 64 bit Robot).
    On one of our computers I have the same bahavior.Switching between views (several times), refreshing them manualy etc refreshes view on this viewport.
    Rafal Gaweda
    Product Support
    mateaus
    10-13-2011 02:24 AM in reply to: RG_Adsk
    The excel file has been created 5 years ago, I don't think this is a problem related to 64 bit Robot.
    Product Support
    10-13-2011 02:28 AM in reply to: mateaus
    No, it was created 09.2001 :-)
    Rafal Gaweda
    Product Support
    Product Support
    10-13-2011 05:59 AM in reply to: RG_Adsk
    Update to "your" macro to set map display on view and to make screen capture
    Read comments in code below
    Public Sub CreeVueRM()
    ' définition d'une vue
    robapp.Interactive = True
    robapp.Visible = True
    robapp.Project.CalcEngine.Calculate ' calculate model
    Dim mavueRobot As IRobotView3 ' this is important to set IRobotView3 if you want to make screen capture of this view
    Set mavueRobot = robapp.Project.ViewMngr.GetView(1) ' it seems CreateView makes this strange affect, use GetView instead
    mavueRobot.Selection.Get(I_OT_CASE).FromText ("3") ' selecting case for results display
    ' displaying map
    mavueRobot.ParamsFeMap.CurrentResult = I_VFMRT_GLOBAL_DISPLACEMENT_Z
    ' making screen capture
    Dim ScPar As RobotViewScreenCaptureParams
    Set ScPar = robapp.CmpntFactory.Create(I_CT_VIEW_SCREEN_CAPTURE_PARAMS)
    ScPar.Name = "My screen capture"
    ScPar.UpdateType = I_SCUT_UPDATED_UPON_PRINTING
    mavueRobot.MakeScreenCapture ScPar
    End Sub
    Rafal Gaweda
    Product Support
