• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Distinguished Contributor
    faisal.aaouatif
    Accepted Solution
    Columns calculation
    244 Views, 10 Replies
    01-06-2013 10:34 AM
    would the message in the attachement mean that the calculations with bending are concidered or not ( regarding the the ligne just above )
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Columns calculation
    01-07-2013 12:39 AM in reply to: faisal.aaouatif
    This means that bending has not been take into account for fire resistance calculations.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    faisal.aaouatif
    01-07-2013 02:56 AM in reply to: Artur.Kosakowski
    Ist there any reason for that or is it a limitation to the current version of the software ?
    Is all the warnings appearing between two message numbers are only relative to the firt one ?
    thank you
    Product Support
    Artur.Kosakowski
    01-07-2013 03:03 AM in reply to: faisal.aaouatif
    What is the design code you selected?
    Could you send me this example?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    faisal.aaouatif
    01-07-2013 03:19 AM in reply to: Artur.Kosakowski
    Calculation option  BAEL91 mod99 Regulation BAEL91RPS2000.
    having a a problem with my model : connot generate ULS and SLS combinations ( only ACC are generated ! ).
    thanks for support
    Product Support
    Artur.Kosakowski
    01-07-2013 03:50 AM in reply to: faisal.aaouatif
    Send me the rtd file please.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    faisal.aaouatif
    01-07-2013 04:08 AM in reply to: Artur.Kosakowski
    ok , not managed to upload to autocad360 , please find a link blelow :
    http://wtrns.fr/pnjYq_8Zq2Vdmr
    thanks
    Product Support
    Artur.Kosakowski
    01-07-2013 05:02 AM in reply to: faisal.aaouatif
    You have to define relations among load cases (see the attached picture)
    Which RC column shall I look at?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    faisal.aaouatif
    01-07-2013 08:20 AM in reply to: Artur.Kosakowski
    Exporting the column 727 for example
    Product Support
    Artur.Kosakowski
    01-08-2013 01:27 AM in reply to: faisal.aaouatif
    The warning informs that the estimated method for fire resistance is not applicable for bending. It can only be used for compression and slenderness below 35 as stated in DTU P 92-701.
    The exact method for bending is not available in Robot yet as far as I know you the freeware named CIMFEU for this kind of calculation is available from:
    CIMbéton
    7, Place de la Défense
    92 974 Paris-La-Défense Cedex
    +33 (0) 1 55 23 01 12
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
