• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Product Support
    Artur.Kosakowski
    Re: Columns Calculation Note
    02-29-2012 07:49 AM in reply to: faisal.aaouatif
    I have just noticed that you replaced the files in the different folder than I indicated:
    Please replace the original files in C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2012\DBAccess
    replaced files in the directory "C:\Program Files (x86)\Common Files\Autodesk Shared\Structural\COM\2012\DBAccess
    Artur Kosakowski
    Support Specialist
    Product Support
    Please use plain text.
    Distinguished Contributor
    faisal.aaouatif
    03-01-2012 01:34 PM in reply to: Artur.Kosakowski
    sorry for the inconveniance but i couldnt find the DBacess directory  in the "C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2012\" folder , so this is why i  used the Program Files (x86) one ....
    anyway (having no time to go further) , im trying to install rsapro2012 in a completly new machine on win7 pro 32 bits
    i hope i'll get no problem ....
    thanks a lot
    faisal.aaouatif
    03-03-2012 09:00 AM in reply to: Artur.Kosakowski
    after new installation of rsa2012 things goes ok.
    thx
    stroxy
    09-18-2012 01:20 AM in reply to: faisal.aaouatif
    2.By examining the calculation Note ; i've found these remarks -- please See attachements ::
      2.a Problem in calculation final excentricity
      2.b Very big Moment magnificient coeffient
    Hi Artur
    I am having the same issues as above and following the thread, I think the explanation to the issue was somehow lost in the other details.  Could you please comment on that issue specifically?
    Product Support
    Artur.Kosakowski
    10-01-2012 06:38 AM in reply to: stroxy
    Stroxy,
    Please check your acting axial force vs. the critical force for this column. My assumption is that you it is either very close or above it.
    Artur Kosakowski
    Support Specialist
    Product Support
