Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Column head
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: Column head
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
As you wrote
. Or if this is only for punching check add this info in the RC Slab Design module only.
Artur Kosakowski
Support Specialist
Product Support
Re: Column head
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Topic good.
You can tutorial step 3: use rigid link.
I is attachment file.
Re: Column head
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Artur Kosakowski
Support Specialist
Product Support
Re: Column head
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
HI. thank you.
But why show slab Punching????????
Thank agian
Re: Column head
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This approach is not intended for verification of the punching. In such case you should decide on one of these instead:
- Make hole in plate and insert plate with another thickness
- Select FE and define plate with new thickness
- Or if this is only for punching check add this info in the RC Slab Design module only
In addition make sure you defined either a 'real' column (bar) under a slab or a support with the determined size (advanced properties of the support) and you do not have any beam in this location. This is necessary for the correct detection of the punching verification points.
Artur Kosakowski
Support Specialist
Product Support
Re: Column head
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you is reply.
Can you give me an example of "Or if this is only for punching check add this info in the RC Slab Design module only". ???????????????
Re: Column head
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here you are
Artur Kosakowski
Support Specialist
Product Support
Re: Column head
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
THanks
You can send modol for me???.
Please .......
Thanks.
Re: Column head
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Artur Kosakowski
Support Specialist
Product Support
