• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Moderator
    Romanich
    Column head
    318 Views, 9 Replies
    06-22-2012 01:07 AM
    What is a best practice to model column head in Robot?
    I know some:
    1. Make hole in plate and insert plate with another thickness
    2. Select FE and define plate with new thickness
    3. Use rigid links
    Also, I’m trying to use FE thickness variable along line, but it very no handy.
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Column head
    06-22-2012 01:10 AM in reply to: Romanich
    As you wrote :smileyhappy: . Or if this is only for punching check add this info in the RC Slab Design module only.
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Distinguished Contributor
    Re: Column head
    10-02-2012 08:48 PM in reply to: Artur.Kosakowski
    Topic good.
    You can tutorial step 3: use rigid link.
    I is attachment file.
    Product Support
    Artur.Kosakowski
    Re: Column head
    10-02-2012 11:33 PM in reply to: A.wikipedia
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Re: Column head
    10-03-2012 12:05 AM in reply to: Artur.Kosakowski
    HI. thank you.
    But why show slab Punching????????
    Thank agian
    Product Support
    Artur.Kosakowski
    Re: Column head
    10-03-2012 12:17 AM in reply to: A.wikipedia
    This approach is not intended for verification of the punching. In such case you should decide on one of these instead:
    • Make hole in plate and insert plate with another thickness
    • Select FE and define plate with new thickness
    • Or if this is only for punching check add this info in the RC Slab Design module only
    In addition make sure you defined either a 'real' column (bar) under a slab or a support with the determined size (advanced properties of the support) and you do not have any beam in this location. This is necessary for the correct detection of the punching verification points.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Re: Column head
    10-03-2012 01:04 AM in reply to: Artur.Kosakowski
    Thank you is reply.
    Can you give me an example of "Or if this is only for punching check add this info in the RC Slab Design module only".  ???????????????
    Product Support
    Artur.Kosakowski
    Re: Column head
    10-03-2012 01:29 AM in reply to: A.wikipedia
    Here you are
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Re: Column head
    10-03-2012 01:32 AM in reply to: Artur.Kosakowski
    THanks
    You can send modol for me???.
    Please .......
    Thanks.
    Product Support
    Artur.Kosakowski
    Re: Column head
    10-03-2012 01:46 AM in reply to: A.wikipedia
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
