• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    andrea.pontiggia
    Accepted Solution
    Coefficient of homogeneity for concrete structure
    191 Views, 3 Replies
    10-04-2012 10:43 AM
    I wanted to know if you can change the value of the coefficient of homogeneity n (or m), for the calculation of concrete structures.
    thanks
    Andrea
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Coefficient of homogeneity for concrete structure
    10-05-2012 12:27 AM in reply to: andrea.pontiggia
    Which code and which point of the code do you mean please?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    andrea.pontiggia
    10-05-2012 01:06 AM in reply to: Artur.Kosakowski
    Italian Code NTC 2008 par. C4.1.2.2.5 " Nei casi in cui si ritenga possibile effettuare un'unica verifica indipendente dal tempo, si può assumere un coefficiente di omogeneizzazione n fra i moduli di elsticità di acciaio e calcestruzzo pari a 15."
    Andrea
    Product Support
    Artur.Kosakowski
    10-05-2012 01:16 AM in reply to: andrea.pontiggia
    Assuming that you want to introduce this change to EC2 design that of RC elements available in Robot then this is not possible. The ratio is calculated based on properties of selected concrete grade and steel.
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
