Code combinations
Code combinations
stroxy
Code combinations
stroxy
What is the difference between ACC, ACC+ and ACC-  (same goes for ULS, ULS+ and ULS-, as with SLS too). I understand somehow that they are the min and max values.  If that is the case, what values are displayed on say "diagrams for bars" when I select the ACC combination.
Artur.Kosakowski
Autodesk Support
Autodesk Support
These are the filters for top and bottom envelopes intended for the results displayed in the tables.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
dimogrec
for example, open the force table -> global extremes, select a bar (if not all) and then choose the ACC cases to see how it works. First ACC-, then ACC+ and finally ACC...
e2009355
Could we use different codes in robot structural analysis to design one building? For example : material use eurocode (c25/30 for concrete) and deign use aci.
