• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    athurD
    Accepted Solution
    Code ??? INTERACTION DIAGRAM FOR SHEAR WALL
    515 Views, 14 Replies
    07-14-2012 02:30 AM
    Hi. I don't see robot code caculation INTERACTION DIAGRAM FOR SHEAR WALL
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Code ??? INTERACTION DIAGRAM FOR SHEAR WALL
    07-16-2012 12:14 AM in reply to: athurD
    Such sort of results is not available for shear walls.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Mentor
    tony.ridley
    07-16-2012 03:51 AM in reply to: Artur.Kosakowski
    because you wouldn't design one for out of plane moment, hence the name shear wall
    PatrickSt-Louis5310
    07-24-2012 11:44 AM in reply to: tony.ridley
    That's a good question,
                                           It's time to ARSAP team to include this option in oder to complete the solution for seismic desing calculations, we can start by doing it for rectangular shape in a first time,and after for the other configurations. That would really help ARSAP users,still also waiting for RC desin of diferent shpae of pile cap in oder to complete de foundation design modulus.
    athurD
    07-24-2012 12:14 PM in reply to: PatrickSt-Louis5310
    Heloo.
    I think Robot version 2014 is INTERACTION DIAGRAM FOR SHEAR WALL.
    athurD
    10-12-2012 08:17 PM in reply to: athurD
    Hi all.
    I tried looking at the code, but I can not find documentation and formulas.
    If you have any documentation about it, you can share to me?
    Product Support
    Artur.Kosakowski
    10-15-2012 02:13 AM in reply to: athurD
    If you are able to indicate any reference that describes the way of designing walls under bi-directional bending and axial force I would be much interested too :smileyhappy:
    Such design is currently not supported in Robot.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    athurD
    10-17-2012 11:08 PM in reply to: Artur.Kosakowski
    Hi.Artur
    I find the theory column. But I do not quite understand, the solution of the column.
    you can provide theoretical royal adjust 3D calculated column???
    Thanks.
    Product Support
    Artur.Kosakowski
    10-18-2012 12:04 AM in reply to: athurD
    I'm not sure if I understand your question. As far as I can see these formulas are for calculations of bending moments based on arm of forces (forces in each of reinforcement bars plus force in concrete) where z is the distance to the neutral axis.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    athurD
    10-18-2012 12:13 AM in reply to: Artur.Kosakowski
    Thank Artur.
    I need the document (book , formula...) about  INTERACTION DIAGRAM FOR COLUMN 3D .
    You can give me document  about it?
    I was looking for, but it was too little.
    Thanks.
