Check SLS Eurocode cracking with seismic load
andrea_pontiggia
andrea_pontiggia
Do I have to verify cracking with seismic combinations. The law is the Eurocode with attached French.
Robot apparent, subsequently cracking only (real armor) with SLS conditions and not with ACC.
How do I add also the combinations ACC checks relevant to the SLS?
thanks
Andrea
Artur.Kosakowski
Autodesk Support
Autodesk Support
You can manually create such SLS combinations as shown on the attached picture.
Which part of EC2 or EC8 covers the calculations of cracks for earthquake situation?
Artur Kosakowski
andrea_pontiggia
It is actually a request from my client ...
I tried to do differently (see attached image), or changing the chart type combinations.
What do you think?
thanks
Andrea
Artur.Kosakowski
Autodesk Support
Autodesk Support
The way you assign the type of combination should not matter. This should work in the same way too.
Artur Kosakowski
