• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    andrea.pontiggia
    Accepted Solution
    Check SLS Eurocode cracking with seismic load
    189 Views, 3 Replies
    01-11-2013 07:39 AM
    Do I have to verify cracking with seismic combinations. The law is the Eurocode with attached French.
    Robot apparent, subsequently cracking only (real armor) with SLS conditions and not with ACC.
    How do I add also the combinations ACC checks relevant to the SLS?
    thanks
    Andrea
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Check SLS Eurocode cracking with seismic load
    01-14-2013 12:08 AM in reply to: andrea.pontiggia
    You can manually create such SLS combinations as shown on the attached picture.
    Which part of EC2 or EC8 covers the calculations of cracks for earthquake situation?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    andrea.pontiggia
    01-14-2013 12:54 AM in reply to: Artur.Kosakowski
    It is actually a request from my client ...
    I tried to do differently (see attached image), or changing the chart type combinations.
    What do you think?
    thanks
    Andrea
    Product Support
    Artur.Kosakowski
    01-14-2013 02:38 AM in reply to: andrea.pontiggia
    The way you assign the type of combination should not matter. This should work in the same way too.
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
