• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    zhurukhin
    Change Analysis type to harmonic - not avaliable
    199 Views, 3 Replies
    12-28-2011 10:45 AM
    Hi!
    I want to change Analysis type for load number 13 from "Static linear" to "Harmonic", but this button is not avaliable (please, see attached file).
    Modal analysis is done, results are avaliable. Besides that, I've already changed analysis type for loads 14 and 15. But for load 13 it doesn't work...
    Thank you in advance
    Please use plain text.
    Moderator
    Romanich
    Re: Change Analysis type to harmonic - not avaliable
    12-28-2011 10:58 AM in reply to: zhurukhin
    Try to put Modal case before load case number 13.
    Active Member
    zhurukhin
    12-28-2011 12:43 PM in reply to: Romanich
    Thanks!
    I'll try - if it's a solution, I'll inform you.
    Product Support
    Artur.Kosakowski
    12-29-2011 01:30 AM in reply to: Romanich
    Thank you for helping others.
    The corresponding part of Help
    http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-47BF5B84-1D3B-49C8-AA62-F437868E221-704.htm
    Artur Kosakowski
    Support Specialist
    Product Support
