• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Distinguished Contributor
    faisal.aaouatif
    Accepted Solution
    Center of torsion
    199 Views, 1 Replies
    07-04-2012 02:41 PM
    When using the "Section definition"   module , is there any mean to compute the tortional center of a section (group of walls for ex).
    Please find attached a calculation note of a typical section of stairwell / lift... (without the information ime looking for )
    Thank you
    Please use plain text.
    Product Support
    Re: Center of torsion
    07-05-2012 12:15 AM in reply to: faisal.aaouatif
    Torsion&shear center is calculated only when all segments (walls) are connected -see below:
    Probably your walls are separated in points where you change their thickness.
    If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
    Pawel Pulak
    Support Specialist
    Product Support
    Autodesk, Inc.
