Autodesk Robot Structural Analysis
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Calculatio n Points in Steel Design
- Highlight
- Email to a Friend
Product Manager AEC
i-Theses bvba
Belgium
Re: Calculatio n Points in Steel Design
- Highlight
- Email to a Friend
Dieter,
Hi, I would like to know how the "Calculation points" are considered in the Steel Design > Calculations dialog > Configuration. One has the possibility to indicate the number of points and optionally some characteristic points. By default only "3" is indicated. Help file indicates that "the points are evenly distributed along a member length".Yes, it is like that.
But I still assume that RSA takes the max set of forces into account. What is the use than of indicating characteristic points.
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Steel-design/m-p/3340849/highlight/true#M288 ...
Or am I wrong and should I always indicate the characteristic points for max Fx, max Fy, ... to be sure that all max forces are taken into account?
This must be indicated by user.
Rafal Gaweda
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
So, what about the next scenario:
- the Calculation points are set to 3, so a bar of 3 m is diveded in 2 x 1,5 m to have start, mid and endpoint.
- the max My is at 1 m from startpoint of the bar
How am I sure that RSA takes the value of My,max @ 1m into account and not the ones calculated at the three points, which are less?
So again,
Product Manager AEC
i-Theses bvba
Belgium
- Highlight
- Email to a Friend
Activate addidional check for extreme My.
Rafal Gaweda
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
So that means, by default, RSA does not look at the max moment, axial force and ... for making the code verification.
The user has to check those checkboxes each time then?
Product Manager AEC
i-Theses bvba
Belgium
- Highlight
- Email to a Friend
Yes.
The reason was the time of calculations for large models, large numer of combinations, especialy with seismic
Rafal Gaweda
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Strange. In next screen capture, I use 3 points and didn't check the characteristic points checkbox.
Still, RSA takes into account the max moment, which is at 0,135 * L of the bar, which is also indicated in the Point/Coordinate field of the Results dialog, which is correct, and - don't get me wrong - is great !
Still I don't understand the goal of characteristic points than. With the explanantion of above answers, I would have expected in this case, the maximal moment My,Ed would be the one from the middle of the bar.
Can you clarify this please?
Product Manager AEC
i-Theses bvba
Belgium
- Highlight
- Email to a Friend
Dieter,
Looking at the diagram I assume that you defined a bar force at this point. If you look at it definition dialog you can see that by default the generation of a calculation node in the force location is switched on. This point 'splits' the bar into two calculation elements and check is done in 3 points for each of these elements. By the way this is the reason why this check box (and this functionality) has been introduced to the bar force definition ![]()
Artur Kosakowski
Support Specialist
Product Support
Autodesk, Inc.
