• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    New Member
    edurneb87
    Accepted Solution
    Cables and modal analysis
    184 Views, 1 Replies
    06-20-2012 05:54 AM
    Good afternoon,
    I have the following doubts regarding how to work with cables and accomplish modal analysis:
    1) CABLES
    1.1. When I launch the calculations in the "Steel/aluminium design" module, Robot does not verify the cables. So,
    can the ULS and SLS of the cables be verified using Robot? or the programme just allows us to define them and obtain the internal forces which we should later check on our own?
    1.2. What should I do in order to define an appropriate material for the cable elements? the programme only lets me choose from a given lists of materials, so should I change the default properties of "STEEL" to have the properties that I need to use?
    2) MODAL ANALYSIS
    2.1.In order to determine the natural frequencies of any structure, is it necessary to generate additional nodes on every single member so as for the ressults to be more accurate or can the programme do it on itself? I ask this because I have modelled a simple cantilever beam and if I don´t create intermediate nodes the obtained results are not correct at all.
    2.2. Is there any way of visualising the modal shapes?
    I look forward to your reply.
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Cables and modal analysis
    06-20-2012 06:20 AM in reply to: edurneb87
    1) CABLES
    The Steel Design module is not intended for cables.
    You can create a new material in Job Preferences and use it for a new cable.
    2) MODAL ANALYSIS
    You have to generate them manually. You can also set the mass matrix as consistent.
    As deformation diagrams.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
