• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Contributor
    ilja.jevglevski
    CPU (cores) usage
    140 Views, 3 Replies
    12-05-2011 07:05 AM
    Very easy question: why robot dont use all cores due model/mesh generation/calculation? For example on my machine i have 8 cores and robot use only 4 of them. Whats the reason?
    Please use plain text.
    Product Support
    Re: CPU (cores) usage
    12-05-2011 07:33 AM in reply to: ilja.jevglevski
    Robot can use multiple cores in these situations:
    - FEM calculations with multithreaded solver
    - plate and shells required reinforcement calculations
    - steel design module (in case of simultaneus runs of design - each run on different core \ thread)
    Rafal Gaweda
    Product Support
    Valued Contributor
    ilja.jevglevski
    12-05-2011 08:03 AM in reply to: RG_Adsk
    Its just that what i use at the moment, if you need i can send you a model or a screenshot. I calculate shell model with ca 50000 nodes using multithreaded sover, 4 cores from 8 are in use, maybe i do it in wrong way or some robot calculation options are not correctly configured?
    Product Support
    12-05-2011 08:36 AM in reply to: ilja.jevglevski
    There are no advanced settings for multithreaded solver in Robot.
    If there are some limitations you can most likely find them here:
    http://software.intel.com/en-us/articles/intel-mkl/
    Rafal Gaweda
    Product Support
