• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    BertelliMarco1095
    CLADDING AND LOAD DISTRIBUTION
    674 Views, 13 Replies
    05-30-2012 03:05 AM
    Dear all,
    I use the cladding feature froms its addition in robot and is very usefull.
    Today I was designing a rectangular slab with in the cernter a circular hole. I added a rectangular cladding and then a circle: you see on the screen that the circle forms an hole on the cladding. after the calculation if I look the the load ridistribution, i see that the hole is not considered! if I check the reaction the give the same result!
    is this a bug or my procedure is worng? PLease find attached the example file.
    Please use plain text.
    Member
    boele035
    Re: CLADDING AND LOAD DISTRIBUTION
    05-30-2012 03:13 AM in reply to: BertelliMarco1095
    You didn't add the RSA-file to your question so I hope I did understand your question correctly.
    I think you must ad the whole in your cladding as well.
    greeting,
    Henk Boelens
    Product Support
    05-30-2012 04:27 AM in reply to: BertelliMarco1095
    It should work. If not please attach example.
    Rafal Gaweda
    Product Support
    BertelliMarco1095
    05-30-2012 05:47 AM in reply to: boele035
    now the file should be attached
    Product Support
    Artur.Kosakowski
    05-30-2012 06:20 AM in reply to: BertelliMarco1095
    The distribution algorithm is not capable of correct detection of openings that stretch up to the edges of a cladding itself. You should either create two claddings and no opening or reduce its size.
    Artur Kosakowski
    Support Specialist
    Product Support
    BertelliMarco1095
    05-30-2012 06:27 AM in reply to: Artur.Kosakowski
    ok
    thanks very much
    Active Contributor
    jamalsid
    08-21-2012 02:33 AM in reply to: BertelliMarco1095
    Hi
    how did you get the load distribution pattern to display like that?
    Product Support
    Artur.Kosakowski
    08-21-2012 02:40 AM in reply to: jamalsid
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Contributor
    jamalsid
    08-21-2012 02:41 AM in reply to: Artur.Kosakowski
    Wow, that was a fast reply!!
    Thanks, knew it would be something simple.
    Active Member
    05-04-2013 07:51 AM in reply to: jamalsid
    hey,
    I am having problems with load distribution on the inclined roof, I added a load on the cladding but it is not distributed on the pannels. I put the load distibution in the right direction as seen in the attachement. It is working for the cladding on the columns.
    Gabriel Habib
