• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Member
    Accepted Solution
    Brazilian codes in Autodesk Robot
    586 Views, 13 Replies
    08-10-2012 07:54 AM
    Hello everybody.
    The Brazilian codes (NBR 6118 for concrete, and NBR 8800 for steel) are not present in Robot. Is there a plan for them to be included?
    What do you do when you’re working in projects for Brazil?
    I’m sorry if this question has been answered before, but I did a search and found only one topic, that doesn’t directly answer this question.
    Thank you all.
    Ricardo Duarte, Eng.
    Please use plain text.
    Distinguished Contributor
    gustavo.c.vasconcellos
    Re: Brazilian codes in Autodesk Robot
    08-10-2012 02:05 PM in reply to: rdproj
    Hi Ricardo,
     I do the following:
    - For steel, I use the US code
    - For Concrete, I use the Eurocode but I changed the combination and I created a Brazilian rebar database, with 6,3mm, and 12,5mm, and removed 6,12, and 14.
    If you need more infomation, please let me know.
    Gustavo
    Member
    08-20-2012 05:03 AM in reply to: gustavo.c.vasconcellos
    Thank you Gustavo,
    In the future, maybe I'll ask you again.
    Are you Brazillian?
    Thanks again.
    Valued Contributor
    Rafacascudo
    08-20-2012 11:03 AM in reply to: rdproj
    Now we are 3 :-) Rafael
    Member
    08-21-2012 07:17 AM in reply to: Rafacascudo
    Hi Rafael,
    Two and a Half! I'm Portuguese!
    But, I'll be working in Brazil next month, so I hope to have your help!
    Ricardo
    08-26-2012 07:25 PM in reply to: Rafacascudo
    Rafael, temos mais um para brigar com a gente. Gustavo
    09-12-2012 04:04 AM in reply to: rdproj
    Seja bem vindo Ricardo!! Gustavo
    New Member
    01-11-2013 06:10 AM in reply to: rdproj
    Olá amigos,
    Trabalho com estruturas há 10 anos, mas estou com grande dificuldade em aprender o programa por completa falta de referências (cases) e documentação.
    Estou fazendo especialização em estruturas e estou interessado em fazer o meu TCC no Robot, mas sem referências é dificílimo.
    Alguém interessado em me prestar consultoria remunerada?
    New Member
    01-14-2013 03:14 PM in reply to: rdproj
    Even using the American Steel codes, there are no metric steel profiles so we can use,
    and it would be so much better if the brazilian code were avilable
    Valued Contributor
    Rafacascudo
    01-31-2013 03:50 AM in reply to: rogerscapini
    quais são suas duvidas?
