• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    jeanne91
    Accepted Solution
    Bent bars reinforcement method
    377 Views, 7 Replies
    09-05-2011 10:18 AM
    Perhaps i don't know how to use bent bars (double bend) cause in 2011 version there is a bug every time i tried to put them manually because automatically it seams IMPOSSIBLE
    I don't undertstand, in older version (2010 and 19) it is simple to use them. I pry you to help me because i have one entire project in 2011 version (beams), i cannot convert them in 2010 and i cannot use the bent bars. Help me it's very serious
    Please use plain text.
    Product Support
    jad.dellel
    Re: Bent bars reinforcement method
    09-06-2011 04:28 AM in reply to: jeanne91
    Hi Jeanne,
    Wich code do you use? EC2, BAEL, BS8110, ACI318-02, ...?
    I assume by your explanation that you want to have reinforcement like this:
    Right?
    Jad DELLEL
    Structural Engineering Product Support Autodesk, Inc.
    Active Member
    jeanne91
    09-06-2011 04:48 AM in reply to: jad.dellel
    It is exactlly what i want
    In general preferences i use France as regional settings
    In job preferency i use BAEL 91 mod 99
    Thanks in advance, i am waiting impatiently for an solution
    Product Support
    jad.dellel
    09-06-2011 05:02 AM in reply to: jeanne91
    If you use the BAEL code, It will be fine :smileywink:
    So,
    1- you've to check the reinforcement pattern:
    2- add a concentrated load, switch on the suspended option and enter the  distribution lenght:
    You'll find attached an example done on RSA2011_SP6, if you don't install the last updates of RSA2011, please check them here: http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=13140816
    Jad DELLEL
    Active Member
    jeanne91
    09-06-2011 06:07 AM in reply to: jad.dellel
    I find the problem
    It is a bug in the definition of the suspended load, When i use relatived dimension to define loads cordinates it works
    But When the option "relatived dimension" is disable bent bars can't be used
    You can see pictures on attached files
    Thank you very much
    Product Support
    jad.dellel
    09-06-2011 06:12 AM in reply to: jeanne91
    Thank you Jeanne for your feedback, I'll be invistigate more deeply this issue.
    Jad DELLEL
    Product Support
    jad.dellel
    09-06-2011 06:28 AM in reply to: jad.dellel
    Jeanne,
    You're right, the workaround for this is to enter the real position of the concentrated load and switch on after the "Relative dimensions" to convert this distance automatically, thank you for your help and i will give you a kudo for this :-)
    Jad DELLEL
    Active Member
    jeanne91
    09-06-2011 09:24 AM in reply to: jad.dellel
    Thank you
