Bent bars reinforcement method
Message 1 of 9
Perhaps i don't know how to use bent bars (double bend) cause in 2011 version there is a bug every time i tried to put them manually because automatically it seams IMPOSSIBLE
I don't undertstand, in older version (2010 and 19) it is simple to use them. I pry you to help me because i have one entire project in 2011 version (beams), i cannot convert them in 2010 and i cannot use the bent bars. Help me it's very serious
Replies (8)
Message 2 of 9
jad.dellel
Hi Jeanne,
Wich code do you use? EC2, BAEL, BS8110, ACI318-02, ...?
I assume by your explanation that you want to have reinforcement like this:
Right?
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
Message 3 of 9
It is exactlly what i want
In general preferences i use France as regional settings
In job preferency i use BAEL 91 mod 99
Thanks in advance, i am waiting impatiently for an solution
Message 4 of 9
jad.dellel
If you use the BAEL code, It will be fine Smiley Wink
So,
1- you've to check the reinforcement pattern:
2- add a concentrated load, switch on the suspended option and enter the  distribution lenght:
You'll find attached an example done on RSA2011_SP6, if you don't install the last updates of RSA2011, please check them here: http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=13140816
Jad DELLEL
Message 5 of 9
I find the problem
It is a bug in the definition of the suspended load, When i use relatived dimension to define loads cordinates it works
But When the option "relatived dimension" is disable bent bars can't be used
You can see pictures on attached files
Thank you very much
Message 6 of 9
jad.dellel
Thank you Jeanne for your feedback, I'll be invistigate more deeply this issue.
Jad DELLEL
Message 7 of 9
jad.dellel
Jeanne,
You're right, the workaround for this is to enter the real position of the concentrated load and switch on after the "Relative dimensions" to convert this distance automatically, thank you for your help and i will give you a kudo for this 🙂
Jad DELLEL
Message 8 of 9
Thank you
Message 9 of 9
stroxy
Does this also work for primary/secondary beams exported from the analysis module?
