• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Mentor
    AJA14
    Automatic Load Combinations
    237 Views, 2 Replies
    11-02-2011 11:19 AM
    I have a building in a seismic zone. I have created the seismic loads. When I try to generate automatic combinations using ACI 2002 it doesn't include the seismic loads. I can only get the seismic loads included when I change the code for the loads from ACI 2002 to LRFD. What seems to be the problem. Is that something to do with robot or am I doing anything wrong.
    Ali Al-Hammoud
    Structural Design Engineer
    MZ & Partners Engineering Consultancy
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Automatic Load Combinations
    11-03-2011 01:01 AM in reply to: AJA14
    The seismic combinations should be generated as shown on the attached picture. In case it is not done attach the compressed rtd file please. I'll have a look at it.
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Mentor
    AJA14
    11-03-2011 01:43 AM in reply to: Artur.Kosakowski
    Thank you Artur. I was actually disregarding the accidental loads. This works for LRFD but it seems it doesn't for ACI. I will try it when I have a chance and let you know. Thanks again.
    Ali Al-Hammoud
