• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    gustavo.c.vasconcellos
    Autodesk certification expired
    292 Views, 6 Replies
    11-17-2011 06:47 PM
    Dear support,
    I tried to generate a printout composition in a World documentation and I received a message (inside word) that Autodesk certification is expired.
    See attached picture, what should I do? How can I validate the signature.
    I am running Robot 2012 and Word 2007 (Brazilian Edition), on Windows 7 Professional.
    Gustavo
    Please use plain text.
    Product Support
    Re: Autodesk certification expired
    11-18-2011 01:17 AM in reply to: gustavo.c.vasconcellos
    This macro has never been signed.
    We will check what we can do. For now ignore this warning.
    Rafal Gaweda
    Product Support
    11-18-2011 10:31 AM in reply to: RG_Adsk
    Dear Rafal,
    but the print out is not exported to Word even if I ignore the message.
    Gustavo
    Product Support
    11-21-2011 12:16 AM in reply to: gustavo.c.vasconcellos
    Have you enabled macros in Word?
    Rafal Gaweda
    Product Support
    11-22-2011 01:14 PM in reply to: RG_Adsk
    Hi Rafal,
    all the macros are enabled (see attached), in addition of this, I installed openoffice and recieved another error message (see attached).
    Gustavo
    Product Support
    11-23-2011 12:57 AM in reply to: gustavo.c.vasconcellos
    Try this
    open Command Prompt as ADMIN
    then
     unregister ALL ROBOTS you have installed on your computer by command: path_to_robot.exe / unregserver
    eg:
    "C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2011\System\Exe\robot.EXE" /unRegServer
    (use such line as above in this Comand Prompt window)
    then
    register the one you want to use.
    eg:
    "C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2012\System\Exe\robot.EXE" /RegServer
    then check
    Rafal Gaweda
    Product Support
    11-23-2011 11:00 AM in reply to: RG_Adsk
    Great, it is working now!!!
    Gustavo
