Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Autodesk Robot Verification and Theory
9 REPLIES 9
Message 1 of 10
heinb
4582 Views, 9 Replies
I am looking for the Robot Verification Manual as well as a theory manual, particular with reference to the finite elements in robot.
9 REPLIES 9
Message 2 of 10
Artur.Kosakowski
in reply to: heinb
The verification manual can be found in en-US\Manuals\Verification manuals folder on Robot DVD.
Surface elements – 3 node triangles (T3) and 4 node quadrilaterals (Q4)
  •  Bending state – elements DKMT / DKMQ (Discrete Kirchoff – Mindlin Triangle / Quadrilateral) [2][3]
  •  Membrane state – elements T3w and Q4w with corrected approximation of membrane state with respect to “drilling rotation” [1]
[1] - IBRAHIMBEGOVIC A., WILSON E.L.,
         A unified  formulation for triangular and quadrilateral flat shell finite elements  with six nodal degrees of freedom . Communications in Applied Numerical Methods.Vol  7, 1-9(1991)
[2] - KATILI I.,
        A new discrete Kirchoff - Mindlin element based on Mindlin - Reissner
        plate theory and   assumed shear strain fields -Part I: An extended DKT element for thick -plate bending   analysis. International Journal For Numerical Methods  In Engineering  , Vol 36, 1859-1883        (1993)
[3] - KATILI I.,
        A new discrete Kirchoff - Mindlin element based on Mindlin -Reissner
        plate theory and   assumed shear strain fields -Part II: An extended DKQ element for thick -plate bending  analysis. International Journal For Numerical Methods  In Engineering, Vol 36, 1885-1908 (1993)
Artur Kosakowski
Message 3 of 10
Romanich
in reply to: heinb
Try to find the path of c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2012\Documents\Verification manuals\
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 4 of 10
ambrozan
in reply to: Artur.Kosakowski
What type of shell element is used in Autocad Robot Structural Analysis Professional
2013 calculations? Is it maybe
the Discrete Kirchoff – Mindlin Quadrilateral
finite shell element??
Message 5 of 10
Artur.Kosakowski
in reply to: ambrozan
 Plane elements – 3 node triangles (T3) and 4 node quadrilaterals (Q4)
[2] - KATILI I.,
[3] - KATILI I.,
Artur Kosakowski
Message 6 of 10
I cannot find verification manual in Robot 2014 folders...
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
Message 7 of 10
Alexei_UA
in reply to: Mirko.Jurcevic
I cannot find verification manual in Robot 2014 folders too.
Can somebody give me a link to download the manual???
Message 8 of 10
Romanich
in reply to: Alexei_UA
Please use this link http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=13093279  or:
Roman Zhelezniak
Message 9 of 10
Mirko.Jurcevic
in reply to: heinb
Thanks Romanich!
I naively thought that Autodesk will publish new manuals for new 2014 version.  😞
Mirko Jurcevic
Message 10 of 10
I just stumbled upon this post. Until 2013, the verification manuals were put on the DVD. They have since been removed due to space.
The Verification Manuals can now be found on the autodesk.com website under Support and Learning.
Here is a direct link:
www.autodesk.com/rsapro-verification-manuals
I hope this helps.
