Hello. I have the following question: when using the steel design in Autodesk Robot, after the calculation, there could be some elements which not verify the resistance.
Can we select the elements in the board after the calculation (image 1 attached) the elements in order to them appear selected in the 3D model, without having to write them in the select box (image 2)?
Thanks.
Ricardo Dias
Solved by Rafal.Gaweda. Go to Solution.
