• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Contributor
    RoboExploiter
    Apply Linear Support to Bar
    105 Views, 4 Replies
    07-10-2012 01:25 AM
    Gents,
    Is it possible to apply a linear support transveresly to a bar?
    I'm trying to model a retaining wall (& including soil interaction) as springs applied along the length of the waler beam.
    I'd prefer not to discretise the beam and apply nodal elastic supports.  I'd like to keep a single bar intact.
    Cheers.
    Please use plain text.
    Moderator
    Romanich
    Re: Apply Linear Support to Bar
    07-10-2012 01:33 AM in reply to: RoboExploiter
    have you tried to use Elastic Ground for bars?
    Active Contributor
    RoboExploiter
    07-10-2012 01:38 AM in reply to: Romanich
    I have considered using this support type, but i'de prefer the versatility of the conventional support definition.  For example I'd really like to be able to fix the longitudinal direction, have springs acting unidirectionally, etc.
    Moderator
    Romanich
    07-10-2012 01:45 AM in reply to: RoboExploiter
    To fix the longitudinal direction you can combine Elastic Ground with nodal support, for springs acting unidirectionally - you can use this option:
    Product Support
    Artur.Kosakowski
    07-10-2012 01:53 AM in reply to: RoboExploiter
    You don't have to divide a bar. It should be enough to define nodes (with supports) along its lenght. In such way you will refer to a single bar number for result's exploration or design.
    Artur Kosakowski
    Support Specialist
    Product Support
