• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Contributor
    kope
    Accepted Solution
    Adding back the initial load distribution presets
    184 Views, 6 Replies
    06-05-2012 01:11 AM
    After tweaking a model for some time I ended up with just the "two-way" preset in the load distribution dialog. I suppose I did delete them by accident though I'm not sure about it...
    Anyway i tried to add them back (i mean the "One-way X" and "One-way Y" presets) but I noticed that the "New" button was inactive.
    After spending some time reading the help, I decided to install the RSA2013 and I opened the same model and all those three presets were there. is there anyone else getting the same problem?
    thanks
    Please use plain text.
    Product Support
    Re: Adding back the initial load distribution presets
    06-05-2012 01:40 AM in reply to: kope
    Scissors button can do that
    It is correct. Three possible options already defined so there is no need to create "new" ones.
    Restarting robot and reloading the file should be enough.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Contributor
    kope
    06-05-2012 01:45 AM in reply to: RG_Adsk
    I still can't get back the presets even if I restart and open again the model in RSA2012 - so I guess there should be something more to do.
    Product Support
    06-05-2012 02:42 AM in reply to: kope
    clear cfgusr folder before next ARSA 2012 start.
    "c:\Users\user_login\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2012\CfgUsr"
    Then start new project and check.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Contributor
    kope
    06-05-2012 03:05 AM in reply to: RG_Adsk
    i cleared it - same thing for the old model - just the "two way" preset.
    but, I noticed something awkward while restarting RSA2012 for several times. If I open a new project and then my old model i got all three options. If I open my old model and then a new project I get just the "two-way" option.
    Product Support
    06-05-2012 03:23 AM in reply to: kope
    So:
    - start new project and follow the red route shown below
    - then load old one, follow green route
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Contributor
    kope
    06-05-2012 04:17 AM in reply to: kope
    Now, that did the trick. Thanks!
