• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    Adding a different thickness to part of a slab
    253 Views, 6 Replies
    08-11-2012 02:43 AM
    Consider the slab on the image, 250mm thick.
    I need to make the gray area on the right thicker, 500mm. Is there a way to "divide" the slab into two?
    I tried the "divide" tool but it doesn't work on slabs in Robot 2012. I then created the slab in gray to the right, on top of the original red one. But then there's another problem: is it possible to trim the red slab somehow? The "trim" tool also seems not to do the job.
    I'm trying not to have to remodel the slab from scratch and re-apply all the loads.
    Thanks in advance
    Joao
    Please use plain text.
    Valued Mentor
    tony.ridley
    Re: Adding a different thickness to part of a slab
    08-12-2012 10:45 PM in reply to: joaocosmoscivil
    For the slab highlighted in red there are 3 options.
    1. Redraw it
    2. After slecting it (and it goes red) hover the mouse on one of the edges you want to move, the edge will go blue.  Then click this edge and you will be able to drag it to the new location (at the edge of the grey panel).
    3. Click on contour definition in the object inspector and manually edit the coordinates of the edge to be changed.
    Tony
    Product Support
    Artur.Kosakowski
    08-12-2012 11:57 PM in reply to: joaocosmoscivil
    If you create a smaller panel inside a larger one the properties assigned to the smaller one will be assigned to surface elements generated there. There is no need to trim the red panel (the overlapped part of the larger panel will not be 'double' meshed).
    For the loads: you have to add smaller panel number (list of elements column in the loads table) to already defined surface loads or define them in the way shown below:
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Mentor
    tony.ridley
    08-13-2012 12:04 AM in reply to: Artur.Kosakowski
    Artur,
    You won't get the "overlapping panels" error with this method?
    Tony
    Product Support
    Artur.Kosakowski
    08-13-2012 12:38 AM in reply to: tony.ridley
    No, you will not. This is a panel within a panel rather than a part of the panel over a part of a panel :smileyhappy:
    This 'cuts off' a part of a larger panel - in the same way you create openings (then it is just an inner contour with no new thickness assigned).
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Member
    08-18-2012 01:10 AM in reply to: tony.ridley
    The problem with this slab particularly is that it's made of lines and curves. By selecting an edge or node, it will drag the adjacent elements - if they're a curve, it will grow really big.
    Probably the best way is to redraw it node by node with lines, two separate slabs. The problem with having one slab on top of the other is that the columns below would be connected to both slabs. That means that the node rigidity would not be calculated right, unless both the slabs would have the same equivalent moment of inertia as one 500mm slab, which is very unlikely!
    Just wanted to know if there was a way to divide the slab into two, like you can do with the bars. But it seems there isnt.
    Thanks for the reply though.
    Joao
    Product Support
    Artur.Kosakowski
    08-19-2012 11:52 PM in reply to: joaocosmoscivil
    1. Draw a line at the border of the thinner and the thicker parts
    2. Mesh the panel as it is
    3. Open the panel definition dialog and define the thicker/thinner part based on the selection of surface elements from either side of the line
    Artur Kosakowski
    Support Specialist
    Product Support
