Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Accelerati on of building due to wind load
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hey there,
I have two questions which are related regarding above subject:
1) Does robot give acceleration of building due wind loa?
2) if yes does it requie nonlinear analysis?
Thank you all in advanc.
Re: Accelerati on of building due to wind load
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The non linear analysis is not required but you need to define how load (wind) changes in time either using time history analysis or harmonic analysis (limited to one type of load change function). For the prior you can get acceleration in nodes directly whereas for the later it is necessary to calculate this value based on obtained displacements.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for your quick responsed but to make the picture more clear,
- If i want to define function to get the accel. "harmoinc function", does it required that the wind to be genarated from ROBOT or it can be done while i express the wind as a static uniform load on cladding ?
Best regards,
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The function is 'applied' to a load case (all loads defined within a load case regardless of their 'origin').
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
See this link.............
tony
