About the SDK application for Optimization using Robot Structural Analysis API
Message 1 of 28
 Question :
                  Does the SDK application will be available in the RSA 2012x64 ? Because it didn't work for the 2011prox64. Can we expect new tutorials and more or additional examples in the manual ?
Replies (27)
Message 2 of 28
Rafal.Gaweda
Autodesk Support
Autodesk Support
Could you be so kind and explain what does it mean?
As far as I can see everything works fine on 32 and 64 bit systems.
Rafal Gaweda
Message 3 of 28
Ok 1
         I have  windows 7x64 on my system, so I have recentltly download the RSApro 2011x64 but when I try to install the folder support \SDK from '' RSA_SDk.exe' it says that it can't find RSA installed. do I have to install the 32 bit version?
Message 4 of 28
Rafal.Gaweda
Autodesk Support
Autodesk Support
SDK installation has been created before ARSA 64 bit release that's why it is not installed.
Please download SDK (then unpack from zip) from link below.
http://www.filemail.com/dl.aspx?id=KVQWIRFWFVLCAMI
Rafal Gaweda
Message 5 of 28
Alpesh
Hi Rafal
Could you please confirm if this is the 32bit SDK.
Could you also repost the download link as it as expired
kind regards
Alpesh
Message 6 of 28
Rafal.Gaweda
Autodesk Support
Autodesk Support
Yes, SDK is 32 bit.
New link here:
https://www.filemail.com/dl.aspx?id=UAAMILDUVWVMOOL
Rafal Gaweda
Message 7 of 28
So ,
         if I understand well, the SDK application still can not be performed on a 64 bit version of RSA, I have also tried to download the file from the  new link and I receive the following warning '' the file has reached the download limit set by uploader and can no longer be download''
Message 8 of 28
Rafal.Gaweda
Autodesk Support
Autodesk Support
To be more clear: SDK is documentation package so it means it does not matter if the system is 32 bit or 64 bit. Just installation was not prepared for 64 bit machines\Robot.
There are 3 exe file examples in it and at least 2 of them should work on 64 bit.
Installation of SDK for 64 bit machines is available on ARSA20112 installation \ DVD.
I am sending new link to SDK
http://www.filemail.com/dl.aspx?id=VNGCTHHGVGUNITL
While writing your own code please remember to select "any cpu" or "64 bit" while compiling code (of course if such option is available)
Rafal Gaweda
Message 9 of 28
can you send the SDK files again please? I have only just installed ARSA and am having similar problems.
many thanks,
Grant
Message 10 of 28
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 11 of 28
Having the same issue... Could you repost the files once again as thay have expired?
Message 12 of 28
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 13 of 28
Would you mind reposting the SDK files for RSA 2013 as the link has expired.
Cheers
Message 14 of 28
Rafal.Gaweda
Autodesk Support
Autodesk Support
Here you are :  http://wtrns.fr/n38vYLqN1Vhj4tM
Rafal Gaweda
Message 15 of 28
HenkaCarlsson
Hi! Can you send the files again please. The download had expired.
Henrik C
Message 16 of 28
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 17 of 28
Hi, Could you please upload again the link, it has been expired. Thank you.
Message 18 of 28
Rafal.Gaweda
Autodesk Support
Autodesk Support
http://goo.gl/abOMt
then File \ Download
Rafal Gaweda
Message 19 of 28
Hi, for some reason it is not downloading properly. Is there a different link or access? Many Thanks. Jose P.
Message 20 of 28
Rafal.Gaweda
Autodesk Support
Autodesk Support
...\x64\Tools\RSASDK  folder on DVD or in unpacked installation in c:\Autodesk
Rafal Gaweda
