• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Contributor
    ARSA Pro 2012 material database error?
    397 Views, 2 Replies
    07-26-2011 11:01 PM
    I have regional settings set to "Eurocode".
    I have materials: set to Eurocode.
    i have default steel set to "S 355"
    When I enter new steel section it shows ok. (pic1)
    But when i start to enter the bar material is empty. (pic2)
    When I try to change wia material , there is no European materials in the list.(pic3)
    Any suggestions?
    ____________________________________________
    If you find my post useful give me Kudos. Thank you!
    If my post solved your problem, accept it as a solution.
    Please use plain text.
    Valued Contributor
    Re: ARSA Pro 2012 material database error?
    07-26-2011 11:08 PM in reply to: Priitl220
    It fixed itself after: Changed to other regional settings and material settings. Closed ARSA few times. Changed back to Eurocode. Now it seems to work.
    Product Support
    07-27-2011 12:54 AM in reply to: Priitl220
    If the change of regional settings is not related to the change of the language of interface (and automatic restart of Robot) then it is necessary to restart Robot manually to fully reinitialize materials.
    Best regards,
    Pawel Pulak
    Support Specialist
    Product Support
