select case \ combiniation , select panel in Robot, run macro
Thank Rafal.
So I don't undertan file excell. You can tutorial .
Please see picture and file.
I'm selecting the panel from robot, i'm defining the combination i want and then i press "get panel selection from robot" from the excel file i get this message:
Knowing that my structure type is shell as you can see from its properties on the left.
Any help?
Johnny
Could you check if it is actually a building (Geometry > Structure type)?
Then try to change it to a shell by pressing on the silo button in this dialog.
Thank you @Rafal.Gaweda, it worked.
If we divide the sum of reactions in this file by the area of the panel, would we get the actual pressure applied by the slab on the soil?
