• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Contributor
    Accepted Solution
    (API) VBA of definition ( uniform planar load and Uniform Load)
    265 Views, 11 Replies
    07-03-2012 07:28 AM
    Hi. . I reading API Load definition but I understan.Please given file VBA uniform planar load and Uniform Load
    Thanks you.
    Please use plain text.
    Re: VBA of definition ( uniform planar load and Uniform Load)
    07-03-2012 08:45 AM in reply to: nhandayasd
    I don't known if i get your problem. With a little help with "Getting Started Guide Robot API", you can get there...
    See the attached file. Of course you need to make your code more robust, than I have in this example, but it is a start point.
    Regards
    Active Contributor
    07-03-2012 09:28 AM in reply to: nhandayasd
    Thanks.
    so you do it.
    Product Support
    07-03-2012 11:48 PM in reply to: nhandayasd
    I do not understand.
    Check additional two buttons in attached xls.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Contributor
    Re: (API) VBA of definition ( uniform planar load and Uniform Load)
    07-04-2012 07:13 AM in reply to: nhandayasd
    yes. Great.
    THanks you.
    Distinguished Contributor
    09-17-2012 09:46 PM in reply to: nhandayasd
    Thanks.
    Please write API given Uniform Load.
    09-18-2012 02:15 AM in reply to: A.wikipedia
    RG_Adsk
    Product Support
    09-18-2012 03:09 AM in reply to: A.wikipedia
    Private Sub CommandButton2_Click()
    Dim Robapp As RobotApplication
    Set Robapp = New RobotApplication
    Dim Loads As RobotCaseServer
    Set Loads = Robapp.Project.Structure.Cases
    Dim Cas As RobotSimpleCase
    Dim Recs As RobotLoadRecordMngr
    Dim Rec_1 As RobotLoadRecord
    CaseNumber = 1
    Set Cas = Loads.Get(CaseNumber)
    Set Recs = Cas.Records
    Recs.New I_LRT_BAR_UNIFORM
    Set Rec_1 = Recs.Get(Recs.Count)
    Rec_1.Objects.FromText "1"
    Rec_1.SetValue I_BURV_PY, 3.23
    End Sub
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    09-18-2012 06:32 AM in reply to: RG_Adsk
    Thanks RG_Adsk.
    But erro.
    You can do same file VBA of uniform planar.
    Product Support
    09-19-2012 01:51 AM in reply to: A.wikipedia
    File attached.
    Next time you will write code, I will correct if needed.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
