• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Product Support
    Re: API Help - Bar lenght and Other
    10-19-2012 03:44 AM in reply to: FilRib
    What should i do to extract data only for 1 point?
    I want data (forces, section propreties, etc...) for the point x=0 of the bar.
    Small modifications and we have a new macro ... attached
    Rafal Gaweda
    Product Support
    Please use plain text.
    10-19-2012 03:45 AM in reply to: FilRib
    Hi again,
    Other question?
    The current output is organized by nodes, i.e:
    BarraCaso
    15317
    15417
    15318
    15418
    15319
    15419
    15320
    15420
    What should i do to have this output:
    BarraCaso
    15317
    15318
    15319
    15320
    15417
    15418
    15419
    15420
    Thanks!
    Product Support
    10-19-2012 03:48 AM in reply to: athurD
    ROBOT_GOOD wrote:
    hi.
    File excel erro ???????
    Macros from this thread do not work with selections made  in robot.
    Fill correct data in Excel cells or modify macro.
    Rafal Gaweda
    Product Support
    Product Support
    10-19-2012 03:55 AM in reply to: FilRib
    Barra Caso
    1 53 17
    1 54 17
    Barra Caso
    1 53 17
    1 53 18
    Just one loop should be changed ... file in message 19, below
    Rafal Gaweda
    Product Support
    10-19-2012 04:02 AM in reply to: RG_Adsk
    You are THE MAN! :smileyhappy:
    Very Very Useful !
    Active Contributor
    RRufino
    10-19-2012 04:28 AM in reply to: FilRib
    Hi Rafal, i tested this last file you sent to user FilRib and something is not ok....because that macro puts forces on end node equal to origin node.
    Product Support
    10-19-2012 04:40 AM in reply to: RRufino
    Yep, my mistake.
    Rafal Gaweda
    Product Support
    Active Contributor
    RRufino
    10-19-2012 06:20 AM in reply to: RG_Adsk
    I think that the successive adaption turned the process too messy.
    I tried this one and i found that for origin nodes some values are not ok (example: My and Mz), on the other hand if you have more then one combination, forces for end node still remains equal to origin node.
    Or am i seeing this wrong?
    Product Support
    10-19-2012 06:44 AM in reply to: RRufino
    No, you are right. To many modifications.
    Check this one.
    Rafal Gaweda
    Product Support
